| Subject |
Out of balance wheel shake will osculate back and |
| Posted by |
ttz'in (NorCal) on November 27, 2014 at 4:30 PM |
This message has been viewed 261 times. |
| In Reply To |
Steering wheel vibration, please help diagnose >> posted by stockplayerz(nyc) on November 23, 2014 at 07:39 PM |
| Message |
forth between shake and not shaking. As mentioned above by others, issue could be other suspension components as well. If rotors turn out to be the problem (which was my issue), the 80 to 85 ft lb specification is too much. Spent months and $$ replacing tie rods, bushings, control arms, even rotors. Before installing 3rd set, a friend who is an aircraft engineer pointed out the force exerted by 5 "tapered" lug nuts, and suggested torque should be no higher than 65 ft lbs + or - 2 or 3 ft lbs. Upon that recommendation, problem was solved and warped rotors are no longer an issue.
| Follow Ups |
Post a Followup |
